Best Heatsink and Fan for 2500 Barton
slickg
Hello,
I'm looking for suggestions on the best possible heatsink and fan for my 2500 Barton. I would assume that all copper would be the best. I am kind of worried about the spacing on my NF7-S as well, I need a heatsink that will fit on that particular board...can you guys give me some suggestions?
Thank you for your time!
I just wanted to make sure, would a volcano 12 fit on my Abit NF7-S? I know there are some size limitations. Thanks
Nah, go for a Thermalright heatsink, they're some of the best. My Barton has an SLK900 on it, runs like a champ @ 2300mhz, @ 36C idle, and 46C load. Or something like that, I never use the damn thing, I'm a Intel boy at heart. heh.
Sell it to me? 🙂
Danger Den, Asetek, Swiftech or Aquastealth water cooling kits, if you really want the best, or if you plan to OC to any reliable degree.
Thermalright SLK900A.
Look at my Sig. I run all my fans at very low rpms, and my system is really quiet.
well the best HSF's for Athlon XP are Thermalright SLK-947, SP-97 with 92mm Tornado, Thermaltake Extreme Volcano 12 ( replace it with a 80mm Tornado), and Swiftech MCX462-V with 92mm Tornado
AMD Athlon XP T-Bred B DLT3C 1700+ @ 2.3GHZ (1.775v) 400FSB = 3200+
Abit NF7-S V.2 (nforce 2 400U)
Corsair TwinX XMS 3200LL 512MB @ 2-3-2-6 (2.6v)
Sapphire Radeon 9500 Pro 128MB
Antec TrueBlue 480W
Thermalright SLK-947U with 92mm Vantec Tornado @2800RPM
Maxtor 91531U3 15GB
2x Western Digital WD400BB 40GB serials
Antec PlusView 1000AMG
Cambridge SoundWorks MegaWorks THX 550 5.1
Sell it to me? 🙂
I can't sell it, my company gave me money to build it as a "work computer." It's a mediocre computer at best, 2300mhz, NF7 motherboard, 512mb corsair, and a gf4ti4400.
