New Job. Start next week. Told to purchase PC tools that I can use in my daily work schedule.
I'm basically a computer hardware tech, and my job will be to remove/repair/order parts for laptops/computers/printers. All form factors will be worked on. Anywhere from removing a system board, to a laptops monitor/keyboard.
I need a small arsenal of tools. From flat/Phillips head screw driver, to a T-10 T-16 type of screw driver, even a small knife for opening packages. An 'all in one tool' is nice, but many times they are difficult to use in that ether they are flimsy, or have a large resistance to switch from one tool to the next. I will be carrying a binder around with me all over this North Western Mutual building. My boss has a small 3-hole pouch inside of his binder with a bunch of unsorted/mismatched tools.
I was wondering if anyone here through experience has a good system of carrying specific tools when taking calls from clients. Is there a good brand of equipment that I should buy? Is buying a 'PC Mod package' smarter? Or is purchasing numerous tools separately smarter?
Basically I need a bunch of tools that are small, will work on smaller laptop components, and larger desktop components. I'd like to magnetize them and can purchase a magnet to do that. Does a stronger magnet make a stronger charge on a screwdriver for example? Reason I ask is that I'm sorta 'shaky' at times for no apparent reason and find a lot of trouble moving around sometimes inside a PC trying to navigate a screw hole without losing the screw under the system board.
