so.. I'm taking this 3D animation course, and they use those huge G5 (or G4, forgot..) Macs and those new iMacs as their computer for in class use.
and I want to build an Intel one myself so I can work on projects at home, but still on a powerful computer.
So what are the most important things to upgrade for a new computer build for 3d animating?
video card, CPU, RAM, etc...
would dual core CPUs help?
the program I'm using is called Maya (by Alias), btw.
thanks!
edit: forgot to include budget >__<
around $1000 max
I've already tried putting together a list, with things like Pentium D 920, 6800GT, 1GB DDR667 RAM, dvd burner, antec case w/ smartpower, asus 955x mobo. it all adds up to just around 1000. I was also considering getting used parts, to lower the price a bit.
hard drive.. I was planning on getting either a 200GB SATA2 or a 74G raptor with a 200GB (possibly external) drive
cooling, will the Zalman CNPS 9500 be sufficient? and a Zalman VF-700 for the GPU, and some fans for the HDDs.
mostly using it for editting/making 3d animation movies.. +modeling and rendering, and creating the final movie in the end.
any suggestions?
thanks!
around $1000 max
any suggestions?
