Is it worth it? I am using the trial version now and am considering purchasing it. But I want to ask around first. It seems to work better but I wonder how it compares to the Windows defragger..
Defraggers are highly overrated. If you are looking for a possible slight performance increase, then a defragger may be for you. And in that case, Windows isn't the best option. If not, don't bother.
