Best Graphics Card for a C2Q Q6600
Red Hawk
3,266
169
I finally got enough spare money to order a C2Q Q6600 off of eBay. I'm curious as to what my upper limit on graphics cards will be now. How powerful a graphics card can I get, from both AMD and nVidia, before the processor starts bottlenecking it and I'm just wasting money?
CurseTheSky
5,401
Overclocking or stock on the processor? 3.0GHz should be easy.
I'd say something like a GTX 460 (either flavor), GTX 560 Ti, or HD 6850/6870 should be perfect. It may be an older Core 2 Quad, but it's still not a slouch.
Red Hawk
3,266
169
Overclocking won't be possible on my motherboard. I got the Q6600 because my mobo is incompatible with anything newer.
toyota
12,957
the amount of bottlenecking can vary wildly from game to game. the fastest I would probably get is a 6850 or gtx460 1gb. it seems AMD gpus are slightly less dependent on the cpu so you might get your best results from the 6850.
SickBeast
14,377
19
I've got a pair of GTX 460 768mb cards, and I'm quite happy with them. The only issue is that the memory becomes a limitation. So long as you're not hitting the memory wall, though, my setup can crush a GTX 580. To get around it I'm sometimes stuck disabling AA, which isn't all that noticeable at 1920x1200 to begin with.
The 1gb cards are better so long as you don't get ripped off on one. I paid $100AR for mine.
happy medium
14,387
480
375 Watt OEM | Acer 1080p 60 Hertz 21.5''
With a stock q6600?
I'd grab a 5770. AT most a 6850, but I don't know if it would be worth the extra money with your cpu.
A gts 450 for 100$ shipped is a good deal also.
http://www.newegg.com/Product/Produc...423R-_-Product
edit:
The Asus 6850 got a nice little price drop at $140AR with a free Shogun game. I'd grab that and sell the game if you dont like it for 15/20$.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121419&cm_re=6850-_-14-121-419-_-Product
bunnyfubbles
12,248
I have to concur with everyone else in concluding nothing faster than a GTX460 (the 768 model should be enough and can be found for under $100 after rebate)
http://www.anandtech.com/bench/Product/314?vs=305
is that what you call crushing? and that's SLI of the 1GB GTX 460model, virtually splitting benchmarks with a single 580, and consuming more power to top it all off
Sure, at nearly half the cost it can provide brute performance at a good value but it's really nothing earth shattering, and for some of us its simply not worth the drawbacks of a multi GPU setup (I actually went from a "faster" SLI GTX470 setup to a single GTX580 because of those drawbacks)
Also, the prominence of aliasing depends on pixel pitch and viewing distance, not resolution. A 1920x1080 resolution on a 27" monitor at 2' viewing distance will need AA far more than 1920x1080 on a 21.5" monitor at the same viewing distance. Saying 1920x1200 doesn't need anti-aliasing (or as much of it) solely on the fact that its a larger than average resolution is conjecture. If we are really concerned about aliasing, 1920x1200 monitors 24" or larger will have pixel pitches that are average at best and thus be less than ideal when it comes to reducing the impact of aliasing. So unless you have a 22" or smaller 1920x1200 monitor, the OP's 21.5" 1080p Acer is actually better than your monitor for reducing the effects of aliasing as long as you both keep your monitors at the same viewing distance.
RussianSensation
19,458
765
I think his GTX460s are overclocked though. Once overclocked, the GTX460 SLi setup can be substantially faster (although can suffer lower min frames). Still for $200-250, it's a "bargain" compared to the 580.
I can see how 2 470s can get quite noisy. However at 750mhz overclock on the GPU, a 470 will come very close to the 480 in performance. Put 2 of those 470s together, and the 580 doesn't stand a chance. This means if a game doesn't scale at all, you will have a setup about 20-25% slower than a 580 but when it does scale, at least 40-50% faster than a single stock 580.
Why didn't you grab 2 6950s instead? For $500, once unlocked to a 6970, they would crush a 580. In the worst case scenario, a single 6950 @ 6970 speeds is about 15-18% slower than a 580 at 1920x1080. That difference narrows down to only 3-5% at 2560x1600. In CF, 6970s would be 50-60% faster than a single 580. In this generation, the 580 made no sense to me. The price premium is enormous. Even factory overclocked 570s were available for 'only' $370. To each his own I guess.
alcoholbob
6,390
469
If you are still rocking the 375W PSU I would get something from AMD on the GPU side.
SickBeast
14,377
19
I call it crushing when I have both of them running at 900mhz instead of the default 675mhz. There is no way that the GTX 580 can even come close to overclocking that well. I have compared benchmarks with my system, and believe me, my 460s crush the 580 provided that I'm not memory-limited.
The 460s shouldn't even come close to the 580 considering that they cost $300 less. Seeing as they can soundly beat it when overclocked, I don't understand why anyone would get the 580 unless they need two of them for SLI.
As for the power draw, the 460s consume way less power at idle, which to me is more important than 20 watts more under load. You also get surround gaming with SLI.
cusideabelincoln
3,275
46
The 768MB SLI doesn't fair very well at all against the 580 in those tests, and will get a lot worse more quickly as time goes on. No amount of overclocking on those cards are going to help it in their Metro, Lost Planet, Civ 5, and SC2 tests.
Umm, that's basically what he said. I'm not sure why you were questioning why he did it and didn't go for another multi GPU setup. He admitted while his setup was faster, like all the setups you just mentioned, he was not happy with it. Presumably noise, heat, power consumption, and micro stuttering are all factors he values more than raw performance. So, to each his own. No guessing necessary.
RussianSensation
19,458
765
I thought GTX460 1GB SLI setup was being compared. If we are talking about 768mb cards, then they would face memory limitations fairly quickly in modern games if you crank AA high enough. But GTX460 1GB SLI setup is very nice, esp. overclocked to 900mhz. Also, if you noticed, I said had he sold his 470s for 6950s unlocked, then there hardly would be any tradeoffs outside of power consumption compared to a 580, esp. if he games at 2560x1600.
arredondo
841
37
To the OP, I was rocking the 5770 for awhile with my non-clockable Q6600 and upgraded to a 6870. There definitely was a jump in frame rate as a result for the games I play. I was in the middle of Dragon Age: Origins using the High Def model mods, and big battles and traveling in large open areas were significantly smoother. I'd recommend the 6870 in a heartbeat for your setup.
cusideabelincoln
3,275
46
The 1GB is fine solution, but SickBeast said he had the 768MB versions, and his comments about his setup are the root of this side-discussion.
bunnyfubbles
12,248
which is why I said it can be a good deal :p but even those minium frame rate of the 580 can be much higher than the average frame rate advantage the 460 has, which I will take any day as long the average frame rates are within single digits.
I went with a GTX580 for several reasons
1.) I was lucky enough to grab an ASUS DirectCU II GTX 580 for ~$380. Triple slot cooling makes the thing virtually silent relative to the rest of my system, even under full load and my moderate overclocking. I also did it to get rid of unavoidable drawbacks with CF/SLI.
2.) 2 x 6950s are easily one of the best deals for a high end setup in forever, however I am no longer gaming on my U2711, so I really didn't need that kind of power, not that it would have been much of an upgrade over my GTX470s (which were overclocked). And the biggest reason I wouldn't go AMD is because I need CUDA, although I am near the point where I could run separate rigs for work and play, but not quite just yet.
3.) I now almost exclusively game on my BenQ XL2410T, a 120Hz monitor with 0ms input lag which I vastly prefer over a higher resolution, as I almost exclusively play competitive shooters. Microstutter and AFR's inherent input lag were just too big of a drawback in my experience, and of course vsync to mitigate microstutter is not an option due to that added input lag.
Interesting considering I can get my GTX580 up to 950MHz, although I don't like to because I simply don't need that much GPU power and like to keep a system balanced for noise/power/heat. Also you running your 460's @ 900MHz just means that much more power they consume and heat they put out relative to my single 580.
Why shouldn't they come close? Its 672 SPs vs. 512. If anything we should be arguing about the 580's MSRP being too high or even the 460s being priced too low
Well I've spelled out my reasons several times so far, I guess one more time won't hurt: I simply don't like the drawbacks of multi GPU setups but still want bleeding edge performance. Seeing as how I need CUDA, I was more inclined to go with a single GTX570 but luckily I was able to grab a 580 with excellent aftermarket cooling for a relatively great price.
? The AT Bench shows the 460s a 7W higher when idle...
Considering the settings I'm used to on my single 1080p 120Hz monitor can push 800MB, good luck running a triple monitor setup with 768MB GTX460s, or even with the 1GB model. Heck, my single 2560x1440 U2711 could push the limits of the 1280MB of my GTX470s.
I originally linked a comparison between the GTX580 and 1GB GTX460 SLI because the AT Bench doesn't have the 768MB GTX460 SLI numbers. My original point was simply to show that a stock 580 can more than hold its own against a setup similar to (but ultimately faster than) a 768MB SLI setup. Sure, the GTX460s naturally have more OC headroom but that's not to say the 580 can't be overclocked at all, and I'm not aware of any benchmarks that readily show a ~900MHz 580 vs. 900MHz 768MB GTX460s, however I would wager the results aren't as "crushing" as some might want to claim.
and again, that's not to say the GTX460, whether alone or in SLI, doesn't make for a bargain (heck, its what I originally recommend to the OP), I just like to keep things in perspective
SickBeast
14,377
19
You know what, "crush" was too strong a term. It just seems appropriate in the sense that $200 worth of 460s can beat out a $500 580. In the games where scaling is near 100%, the 460s will beat the 580. TBH the setups are more or less equivalent under most circumstances.
As for the idle power, the reviews I've read have shown the 460s to have lower power consumption and heat when idle compared to the 580.
It's not like my power draw goes through the roof at 900mhz, either. I'm barely increasing the voltage to run them at that speed, and they only hit 55C under full load. If I really wanted to I could run them at 950mhz as well, but that requires 1.2v, and yes, that would make my rig run pig rich for lack of a better term.
I'm glad that you're happy with the 580. I personally just can't see enough benefit in the single card solution when there is such a large performance delta. If someone offered to trade me their 580 for my 460s straight up, I would do it, due to the greater amount of memory more than anything else.
IMO the drawbacks of SLI are way overblown. I'm fussy, and I have yet to see any microstutter or driver glitches, and I'm not even running my setup on an SLI-certified motherboard.
bunnyfubbles
12,248
Even without aggressive overvolting, @ 900MHz you're likely running ~100W over what you otherwise would be getting at stock. And just because your GPU temps are healthy doesn't mean that extra heat isn't being produced, its just that the coolers are able to dissipate that heat away from your GPUs and ultimately into the room the PC is in...something I'm certainly glad to be rid of going away from dual GTX470s (particularly with summer closing in). It's also pretty much guaranteed the noise levels of my particular GTX580 are significantly lower.
I still don't agree with how you're trying to paint an SLI GTX460 setup is something that is hands down faster than a GTX580. Sure, if we clock all the cards to the same clockrate, the GTX460s will likely have higher average frame rates, but ultimately only by single digit margins all while losing minimum frame rates often by double digits. Again, I'd much prefer the more balanced performance of the GTX580 over the far less stable roller-coaster-ride the 460s would provide, and that's before considering microstuttering which can make the game feel like its rendering at half the frame rate being provided.
Maybe you can't see microstuttering, although I think its more likely you're just acclimated to it. Heck, I was largely acclimated to it, but I could definitely still see it, and moving to the GTX580 made it obvious as my frame rates went down but the smoothness went up. Vsync can alleviate microstuttering problems but that introduces new ones as I have mentioned, and in some cases it just isn't enough such as when you cannot maintain a framerate higher than your monitor's refresh rate.
For instance, while playing Bad Company 2 Vietnam there would be situations on my GTX470s where my frame rate would drop from well over 120fps into the 80-90 range while running through some caves. Now that certainly doesn't sound bad at all, 80-90 should still be more than enough to provide buttery smooth play, but it just felt like it was more like 40-45fps which I can easily tell the difference between that and 60+ let alone 80-90 or 120+fps. Now the same situations on my GTX580 simply do not exist, the game never feels choppy at any point.
At the end of the day, and maybe this is really what you meant all along, the one thing I would agree on is that the GTX460 (regardless of SLI) crushes the GTX580 (especially if bought at MSRP) in terms of price/performance. If I didn't play competitive shooters and still ran a ~1920x or smaller 60Hz monitor I certainly would contemplate the idea of GTX460 SLI as such a setup can be a much wiser choice to provide the raw performance with the multi-GPU drawbacks more readily and willingly mitigated given such circumstances.
SickBeast
14,377
19
Fair enough, bunnyfubbles.
I've used vsync for years now. I personally can't stand the visual tearing that running without it causes. I prefer to deal with the input lag for the sake of the visual quality improvement.
I can see why we each chose our respective setups. I live in Canada, so the extra heat is nice (most of the time). :)
SlowSpyder
17,305
1,002
Good news OP! It looks like you CAN overclock a Dell Deminsion 9200. I did a quick search and found some info.
http://www.starless.nl/overclock (it took a while to load for me, so give it a few minutes if it doesn't pop right up).
According to this guide, Clockgen will let you bump the FSB: http://files.extremeoverclocking.com/file.php?f=189
Just watch your temps, the Dell cooler probably isn't spectacular at removing the extra heat.
With your Q6600 bumped up a bit in speed you'll get a lot more out of a video card. You may be able to look at better cards since the extra GPU power won't be wasted on a slow CPU.
SickBeast
14,377
19
That's going to be hard to overclock if you can only adjust the FSB. You need more voltage to really get anywhere.
There should be programs that will allow this, though, if you look hard enough. If they don't exist that's just bad luck IMO.
