- Dec 7, 2013
- 10
- 0
- 66
not if you want all the effects and good AA quality. I run my GTX 780 at a max res of 1600x900.1600 x 900 being 30% fewer pixels to render compared to 1920 x 1080 ... I would also not go higher than GTX 760 for that resolution. GTX 760 runs 1080p fine as well.
agreed that his CPU is a huge limiting factorHowever, your CPU is the bigger factor here. It will absolutely limit the performance of a GTX 760 in a lot of games, on that resolution. Stock 7950 was very noticeably limited by my i7-920 @ 3.36GHz on 1080p, and prompted me to upgrade to 3770K.
that is beyond ridiculous. so you look at all the settings and in your mind it makes more sense to crank everything but then use 1600x900? it only takes a little common sense to back off on AA levels. and if your monitors native resolution is above 1600x900 then what you are doing is flat out stupid. native res will always look more crisp and all the AA in the world will not make up for the blurriness of dropping below native.not if you want all the effects and good AA quality. I run my GTX 780 at a max res of 1600x900.
Sorry bit off topic op,but do you plan to run that rez forever?sweet mother of god.780?
When he posted something like that it was essentially a thread highjack. It's going to be EXTREMELY hard for anyone to ignore that post.
For that CPU, I'd probably get an R9 270 at most.
Radeon R7 265 is faster than a 750Ti for the same price.
http://www.anandtech.com/bench/product/1127?vs=1130
3 things: 1. i dont see how it is blurry when i use "do not scale" with "perform scaling" set to "GPU" and checked "override application settings". 2. i have it set to 1600x900 so that i can use 75Hz within my monitors pixel clock and get less input lag than it would at 1080p 60Hz. 3. screen res has nothing to do with aliasing so i am not sure what you mean when you say that i should back off of AA before decreasing resolution.that is beyond ridiculous. so you look at all the settings and in your mind it makes more sense to crank everything but then use 1600x900? it only takes a little common sense to back off on AA levels. and if your monitors native resolution is above 1600x900 then what you are doing is flat out stupid. native res will always look more crisp and all the AA in the world will not make up for the blurriness of dropping below native.
