Best Graphic Card For CS-GO
JustJustin26
Homosexual marriage was legalized in Luxembourg few month ago. Gay and lesbian marriage is now officially approved and protected by the Luxembourg constitution.
However, while the crowd begin to accept gays and lesbians, the situation gets somehow different on one heterosexual dating websites. Recently, compatiblepartners, onlylads, mygaysites well known dating sites, declared that the sites are dedicated to homosexual individuals only..
They want to provide a place where everyone has the same orientation. Same interest is very important when it comes to dating, more important for the homosexual people. It would be a very unpleasant experience when you come across someone on the website and want to say hi but he replies 'sorry, I'm not interested in dudes'."
"This isn't about discrimination at all. As part of the LGBT community, we certainly know what it's like to be prejudiced and no one wants feeling." O'Neil added, "However, we want to create a more dedicated platform for our members. I'm sure there are sites that are for bisexuals, where they will have a much bigger chance to meet that one."
Unlike any other dating sites, match.com doesn't allow its members to select their "gander". The only option is for "homosexual" to meet "homosexual", which means if you're a member, you could only be homosexual. However, O'Neil mentioned another term which sounds a little bit vague, "homo-curious". “There are people who are curious about homosexuality. They might be uncertain about their sexuality thus can’t identify themselves as ‘homosexuals’, but as long as they’re interested in men, I don’t see why we shouldn't give them a big welcome.”
According to O'Neil , any profile that claims to be heterosexual will be deleted. "We will notify the member that "Match" isn't a straight dating site when we delete their profiles. We wish them all the best on other straight dating sites." said O'Neil.
"Match" was started over 5 years ago with the goal of providing a safe, private dating platform for homosexual individuals meaning gays and lesbians. With over 13 million active members at the moment, it is the largest online dating website for homosexuals.
Source: Reddit news
lehtv
11,897
74
For CS:GO, the processor matters. You'll preferably want an Intel i3, possibly even i5. From what I know, the Source engine uses three CPU threads, which rules out dual cores such as Pentium. The engine also benefits from fast cores so Intel is preferred over AMD.
As for the graphics card, what monitor resolution do you use? Many play this game at 1024x768 where it runs very smoothly even with an older or lower end gaming GPU. For 1080p, get at least a GTX 750 Ti, preferably GTX 960.
Not sure if this is true but I've read that pro CS:GO players prefer AMD graphics cards because there's some potential (and probably small) input lag issue with NVIDIA on Source engine. So you might want to also look at AMD cards such as R9 270(X), 370.
JustJustin26
Thanx for your answers, i was thinking to buy rest of the hardware based on what graphic card will I pick. R9 390x Isn't bad idea tho. It is kinda expansive but still you buy one good PC on 3-5 years, so it should last.
SPBHM
5,076
440
390X is totally overkill for CSGO I think... you will probably be more than good with something like 270.
moonbogg
10,736
3,454
That game requires almost zero GPU power. An HD 7850 would be plenty to get over 100FPS in that game, and any quad core CPU would be more than enough. You could buy old used parts and spend very little money and still get 200FPS with that game. Google some benchmarks and shop for hardware. Even an HD 6870 gets 100FPS in that game.
16,432
What are the specs on the rest of your system? If you're on an old Dell, for example, you might not be able to plug an x16 PCI-E GPU in anyway, so our recommendations will be moot. But as others have mentioned, CS: GO really isn't terribly intensive from a GPU standpoint, so any midrange card from the last couple generations will easily max it.
sm625
8,172
137
It needs 4 threads. It does not need 4 cores. i3 is perfect for this game. And it should be just fine paired with any $120 card.
skipsneeky2
5,035
I got a gtx650 and if you disable motior blur and msaa its more then enough to deliver 60+ fps at 1080p.
I wouldn't buy a 650 if i was you but it gives you a idea of performance that is needed.
Prey2big
110
I used to play CSGO with a Radeon 6870 1GB, and it could run 1080p with max settings and 4x MSAA and maintain way above 128+ fps at all times. (CPU was a Core i7 2600).
You should have no problem finding a card today with similar performance or better for fairly cheap.
