😉 Yup.
🙂 Rad8500/9000 type cards are great value for money (in countries where they're priced among the GF3 cards) but these cards generally gain very little from P4's faster than 1.6ghz and are let down by their AA perf. Great '2D' image quality, DVD playback, TVout and dual display though. For $150ish a GF4TI4200-128MB is a great card and they tend to o/c VERY well. If you can stretch to $200ish then you should find 4600 are hardly much more than 4400, as said you're only talking about 10-20% gain over a 4200 most of the time. If you can afford it Rad9700 is clearly the best card in all depts, it will surpass a 4600 in pretty much everything and is clearly king for stacks of AA and Aniso without slowing down, of course your 1.8ghz won't get the most out of it because a 2.53ghz can't, but that bodes well whenever you upgrade the CPU, if you're spending $350+ on a gfx card then you're going to want it to last! As said AGP8x is NOT needed at all to get the most out of Rad9700, in fact it tends to cause more probs than anything else at the mo!
