Best gaming case for cooling?
junpertys
Hi, i'm planning to overclock my pc and would like to buy a really good case .
My budget is about $3000
Anyone have any suggestions?
HAF X is an awesome gamer styled case and top notch for cool, the name itself means High Air Flow. Since its made to be used with large fans I have also found it to be one of the quietest when paired with a fan controller. You fin quickly that temps stay great and you can really wind down the fans.
You can OC a chip in just about any case... it doesn't have to be some gargantuan case. Much depends on how high you want to go and how you intend to cool it. The main parameters are 1) what size mobo; 2) how many drives are going in it; and 3) how many GPUs and how big are they. That will narrow down where you need to start.
For example, my 2500K is OC'd on a mATX board in a small (for a tower) Fractal Define Mini; I have no temperature problems with either the CPU or GPU. Personally, I'm in the 'Bigger doesn't necessarily mean Better' camp...
Case Labs..........with a budget like that you should be doing a custom modular Case Labs case............
+1. If you want to spend your money on hardware, and not as much on a custom case, then the HAF X is a great choice for air or water (room for everything you could possible need for either set up).
Corsair Carbide Air 540 if you want a great air cooled case. Obsidian series is not great for air cooling but is great for watercooling and looks.....
I have the Phanteks Enthoo Primo, air cooled with a Phanteks TC-14PE. Great cooling and a moderate oc (4.1) delidded i7 4770K. Water cooling potential is awesome, but I'm a confirmed "airhead". I also have an NZXT Phantom 630 that cools equally well on air. Those are but two cases that would more than suit your needs.
Rosewill Thor V2. $130, save the rest for upgrading hardware. This thing moves a lot of air very quietly.
I absolutely cannot recommend the Carbide Air 540. I've owned a few Corsair cases over the years (Obsidian 550D, Obsidian 800D, Obsidian 900D, Carbide Air 540), and while they've all had their own issues, the Air 540 is the only one that I loathed after using it. Now, I might be a bit more picky than some users, but there are a few things that I really cannot excuse:
1) This case is just way too expensive for what you get. The case has a $150 MSRP, and it tends to retail for about that much. So, what's the problem? I listed cases up above that cost even more! Well, the issue is that the case feels cheap and looks cheap. That makes sense once you realize that the case is about 50% plastic and 50% steel. Yes, it's constructed much like those cheap, bargain bin $40 white OEM cases. The 550D is a similarly priced case, and even though it also uses considerably more plastic than its pricier brethren (800D and 900D use considerably more aluminum), it looks far better.
2) There is a serious design flaw with the rear case fan. Now, I'm not talking about the idiotic choice to make a removable fan grill on the back (who does that?), but rather the fact that you cannot use most aftermarket fans in that spot. There are two problems that I encountered. The first is that if there's anything in between the space between the mounting holes (such as Corsair's rubber mounts on the AF and SP series fans), that will hit against a lip in the case, which means it cannot reach the mounting points. If you manage to get a fan that doesn't have anything in the way, it also cannot have a square shape! If your fan has a square shape, it will cover the side panel's screw hole, which means you can't screw in the side panel's top thumb screw.
3) There's a serious lack of airflow over the left 3.5" HDD, which caused it to have temperatures about 5C higher than the right drive. It probably also doesn't help that it's right below the video card.
4) The 2.5" drive carriage is built for 9.5mm drives, and anything smaller (e.g. Samsung 840 series SSDs) will wobble in the cage. Given the price tag, Corsair should have included some sort of cable or mechanism to provide power to these drives. The issue that I ran into is that they're all so close together, that it's rather awkward to plug in the power cables. To be fair, this is actually a problem on quite a lot of cases. You should see how much fun it is to use the drive bays on the bottom of the 900D!
Honestly, I think the Obsidian 550D is better than the Air 540, and the temperatures are only 1-3C higher. Of course, I did put a 140mm fan on the bottom (near the PSU) and a 120mm (a 140mm fan wouldn't fit) on the lower mount on the side panel. As you mentioned, Obsidian cases usually have sub-standard air flow, but those two fans really helped to alleviate that. Although, I think the 550D is too small. I would love to see a version of it that's about the size of the 800D.
Hmm I'm not as much of a fan of the looks of that case, but I do like the abundance of air cooling options! Given how ridiculously overkill my 900D is for an air-cooled, single-GPU PC, I'm tempted to try it out.
I love mine. The top part is plastic and pretty useless. The whole front bezel is plastic as well. The older models have USB 3.0 pass through cables, no USB 3.0 header so make sure to get a new model or contact rosewill and get a replacement. Tons of room for HDD's and SSD's with removable trays. Large front fan right in front of the HDD cage for good airflow. Huge fan on the side panel to cool the mobo/cpu/gpu. Filtered bottom mount PSU with another fan bezel right in front of it for expansion. Large exhaust fan on the rear panel and the top. Lots of holes for cable routing, all grommeted. Lots of space behind the mobo tray for excess cables. Will fit ANY air cooler with ease.
http://i1310.photobucket.com/albums/s644/slashgnr101/20140116_193430_zps80c5fd06.jpg
http://i1310.photobucket.com/albums/s644/slashgnr101/20140116_193408_zpsf327962b.jpg
I wouldn't obsess over a 'gaming' computer case because the main thing a PC case can offer is functionality.. and that starts with what do you want out of your case. I started off with a 01-02' PC-60, it was great for my first case but it lacked room for 3.5" drives. I thought the Lian Li PC 2000 Black was the answer. Still lacked the room I needed. That is the basic jist of what drove me to larger cases.. PC cases all do the same thing and can be adjusted to accommodate flaws but size/room is one thing that's hard to 'fix'.
Back to buying a 'gaming' case, ask yourself what is it exactly that you want out of a case, and can it be accommodated for by other means..
the Raven series, with reversed mobo and GPU output on the top are pretty nice too, if you can look past the plastic front cover.
Also, LianLi for all-metal.
I'm looking to pick up the Corsair 900D soon. Looking to build a custom water cooled setup.
It's got some pretty good reviews!
How about a Lian-Li?
http://www.newegg.com/Product/Produc...82E16811112413
I have an older version, and having built computers before and after with other cheap cases, I have really come to appreciate my Lian-Li case. This current one has a lot of great features:
1. All Aluminum construction - good for heat dissipation. I also remember being amazed at how light it was when I got it, although it becomes a moot point when all your components go in.
2. Good air cooling options, with 2 front fans, 1 rear fan, and option of putting in 2 side fans too.
3. Nice internal design, with cable routing options, PSU at the bottom of the case, and enough room for biggish Gfx cards without the whole case being too bulky. I really loved the rubber damped hard drive cases you can just slide and click into place.
4. Understated design with basic front panel USB 3.0 and audio inputs.
Not bad for under $150 I think.
