Nocturnal Lifer Jan 8, 2002 18,927 0 76 Jun 19, 2006 #1 So I'll be receiving my WRT54GL from Amazon in just a few days. I'd like to know which firmware I should flash the router with? Thank you.
JackMDS Elite Member Super Moderator Oct 25, 1999 29,553 430 126 Jun 20, 2006 #2 My first choice is this, http://www.thibor.co.uk/ It is an augmentation of the original Linksys Firmware, same interface and very reliable. If the feature that you are looking for is not available in the latest release then DD-WRT would be next choice. :sun:
C cmetz Platinum Member Nov 13, 2001 2,296 0 0 Jun 20, 2006 #4 Nocturnal, what do you want to do with your router, and what is your skill level? "Best" is situation dependent. At least with the WRT54GL you have choices.
