The drive I'm talking about is the one listed in this Hot Deal Thread (NEC 8X Black Dual Layer DVD+/-RW Drive, Model ND-2510A). Several links point to here to download the firmware but I don't understand what this bitsetting and rip lock and other stuff are.
So could somebody to one of the following:
- Explain what these technical settings are
- Hook me up with links explaining what these things do
- Directly compare these different firmwares
For the most part, I'm using this DVD player for backing up movies and I'm using Longten001 media. What I would like to do is speed up either ripping or burning speeds (if it's possible) without losing any compatability in the process. If none of these firmwares can do that for me, then a second goal would be to increase compatability (if it's possible). If none of these firmwares can do that for me, then I'll likely not have a reason to flash to a different version (unless somebody gives me a reason that I didn't know about).
Thanks in advance for the help and sorry about my ignorance in this field.
