Best fan for taisol heatsink?
Doomguy
2,389
Are there any other high performance 60mm fans besides the delta because I hear the delta is extremely loud. I currently have the stock fan and a sunon 24cfm. Would a faster fan help temps alot? Thanks for your time.
TuffGuy
6,478
which taisol do you have? i'll be putting an 80mm on my cgk760 - 2900rpm, 41cfm, 2.4w.
Phunktion
2,502
Try the YS Tech or the High Speed Sunon.. try this link.. here it oughta give you a good idea about your options..
Doomguy
2,389
Arent 80mm actually not efficent on heatsinks or do they actually work well? I have the cgk760 also.
mikef208
Banned
Nov 30, 2000
3,227
This is just my 2 cents, but I think 80mm fans cause a larger dead spot right over the core which is not good, i think putting two 60mm side by side on the sink would be better, if you search this forum for a thread titled dually Taisol i think, that is a good example.
Doomguy
2,389
Hmm could I put my stock fan and sunon fan side by side on my taisol?? That would be great if I could!!
