Best Fan For Taisol 742! **No Deltas**
MrC4
I am running a Taisol 742 with a 1.2 Gig T-Bird at default voltage. My idle temp is 30 c, but under full load it approaches 50 c.
I hoped to add a better fan that is still quiet and I am open to all suggestions.
Thanks!
I replaced the stock fan with the YS Tech 60mm on my CGK760092 and added a second YS Tech 60mm on the side. My load temp is 45C and idle around 30C.
get the antec1030 for sure. get the charcoal grey. that is an awesome color. I love my case. upgrade to 350 watt and get additional fans and plus it has a lot of room to work with. the price is good too. you can get one for $98 at directron.com.
Gizzo:
You have a Sunon fan listed on your site that gives the same 16 cfm as the fan only one is a Vapo and one is a sleeve. The Vapo is rated at 21db. Why don't you use this Sunon over the 25 db sleeve model?
Sal
