T thawolfman Lifer Dec 9, 2001 11,107 0 76 Feb 5, 2003 #1 I'm just curious... what is/are the best custom options to use for RazorLame? Thanks
Aves Lifer Feb 7, 2001 12,232 30 101 Feb 5, 2003 #2 Use the --alt-presets. --alt-presets Explained I personally use --alt-preset cbr 192
D DaveSimmons Elite Member Aug 12, 2001 40,730 670 126 Feb 5, 2003 #3 There's supposedly an AT FAQ on this, and a very good site for audio encoding info is: www.hydrogenaudio.org
NEVERwinter Senior member Dec 24, 2001 766 0 71 Feb 6, 2003 #5 i prefer --r3mix preset from www.r3mix.net
W Workin' Diamond Member Jan 10, 2000 5,309 0 0 Feb 6, 2003 #6 " Originally posted by: NEVERwinter i prefer --r3mix preset from www.r3mix.net Click to expand... "--alt-preset standard" actually works better than "--r3mix" although that works well, too. See the FAQ in my signature.
S Sid59 Lifer Sep 2, 2002 11,879 3 81 Feb 6, 2003 #7 --alt-preset standard ....if that doesn't sound good to you ... --alt-preset extreme, --alt-preset insane if that heirarchy doesn;t work, you need a better sound card, speakers, and ears ... or maybe a different format. -r3mix is dated, -aps is much better. The whole reason the presets were made was to improve upon the r3mix switch.
