B buckchoi Member Oct 2, 2002 57 0 0 Oct 2, 2002 #3 Well if running WinXP then it can all be done when installing the OS Just follow the easy directions to create a partition during the installation.
RalfHutter Diamond Member Dec 29, 2000 3,202 0 76 Oct 2, 2002 #4 Easiest: Partition Magic Best: Fdisk (Win 9x OS) or, as buckchoi suggested, using the built-in partitioning abilities of XP/2000. Partition Magic is not 100%. If you are going to use it, backup first.
