Best DVD player for a 30" widescreen HDTV?
jsbush
3,871
Looking for the best dvd player I can find for my HDTV. I have no clue how much I should spend, and what to get. Or even if I should get one, will they come out with a new dvd technologie in six months...?
Suggestions please!
Edit: My tv has a DVI connection.
jsbush
3,871
Originally posted by: virtualgames0
htpc?
Thats what I'm using right now. But I'd like to get a standalone dvd player to keep things simple.
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
When i bought my Panasonic 30WX54 30" Widescreen HDTV a little over a month ago i was faced with the same situation. I only had a non-progressive scan dvd player, and needed to upgrade.
The general concensus was that any decent progressive scan dvd player will do, as an upconverting model really dosent help on CRT's.
I needed a sound system as well, so i ended up buying the Sony DAV-FR1 from mysony for $345ish and now have my home theater complete. Its a full 5.1 system with a built in progressive scan 5-disc dvd changer/sacd player. I love it :D
Aug 10, 2001
10,420
Well, you can't go wrong with the Linn Unidisk SC. But it must cost at least a few thousand dollars.
