best drivers for geforce2 mx400 and geforce3 ti200 (yes, ive looked around)
MrDudeMan
15,069
94
are the new detonator drivers (28.32) good for both cards?
both systems are running windows xp and like i said i have a geforce2 mx400 and a geforce3 ti200....help please :)
conlan
3,395
I'm using the latest Detonators, but w/ Win 98SE, they should be fine with XP i would think.
John
Moderator Emeritus<br>Elite Member
Sorry to say this, but there is no "best" driver because YMWV compared to my findings, as well as others. Install the 28.32's and see if they do everything you are looking for.
MrDudeMan
15,069
94
John,
i think you are correct in saying there is no such thing as the best driver....i guess i just worded it funny :) good advice though, i installed the 28.32's and it seems to be working flawlessly on a g2 mx400 and a g3 ti200, both in winxp
hope this helps someone if they have the same question!
thanks again
