Best DC project 4 a celeron 433
rebldomine
48
Intel® Celeron 433MHz (w/128KB L2 Cache) PPGA CPU
128MB SDRAM
56K* ITU V.90 PCI Fax/Modem
thats basically the pertinant stats of the computer i need for the question i think...
edit: i cant overclock because its a emachines... hehe
Polo
4,185
RC5, OGR, ECCp109 are good projects for this kind of machine.
But choose the project you prefer even if it's not the most efficient... ex : SETI isn't a good choice for this machine... ;)
Then, if you choose SETI, you could try to trade your CPU time with another DCer to optimise the performance... Ex : you run RC5 on your machine with XXXX email's addy and XXXX runs SETI on his PII400 for you. This way you are both winners ! :)
Hope this helps ? :)
SlowBones
97
I'd pick the one your interested in. You won't get astounding performance at Seti, but it'll be better than the P200MMX I used for a year or so!
RC5 is cracking codes, OGR is math, ECCP109 is math, United Devices has one for cancer research, and there are others, so pick something that you're interested in, that's the key.
Good luck and welcome to the team! :cool:
Sukhoi
15,350
SETI sucks big time..my C433 is ~16 hr/WU I think, maybe a little higher. I have a CPU trade going on with Poof though, so I get much better WU times from her PIII Xeon 550 MHz. :)
