best current GPU for $150
futurefields
6,470
32
My friend is looking to upgrade his stock HP from 2011, which had a bottom tier nvidia card in it.
Moved from PC Gaming
Anandtech Moderator
KeithTalent
Rhezuss
4,118
34
In this price range...maybe the 650 Ti / HD 7770-7790. I did a quick search over newegg.com to find the best for $150 and looks like it.
If you're lucky you could probably grab a GTX 660 or HD 7850 when a cool sale happens.
nwo
2,308
7770 and 7790 are both sub $100 cards. For $150 I'd say try to get a new/used GTX 660 or Radeon 7850 (2GB) or 7870.
Rhezuss
4,118
34
nwo
2,308
660 is a bit over $150, 7850s and 7870s are no longer produced which is why their prices are inflated. You should easily be able to find all 3 aforementioned used cards for $150 or less.
Rhezuss
4,118
34
Used, for sure, good point :)
Bubbleawsome
4,834
1,204
New? Where? Cheapest I have seen is $180.
At school so blocked newegg but I've seen them at newegg. Then again last time I looked 270x's were 209, now I see them on amazon for $239. Miners. :mad:
3DVagabond
11,951
204
OP, did/does the original card have any 6pin or 8pin external power connectors? Does the power supply have any unused power connectors? If so, what are they?
Or a description (model number and brand) of the power supply would be useful.
Aug 11, 2008
10,451
642
Kind of a switch. A couple months ago, prices were exceptional on amd 7xxx series cards. Now most are badly inflated. I would look for a gtx660.
Ken g6
Moderator
Dec 11, 1999
16,765
4,737
75
I would assume a "bottom tier nvidia card" wouldn't have a 6-pin connector. So I'm gonna go with:
7790 ($100AR) +
Corsair CX430 ($44AR with shipping)
nwo
2,308
7790 ($100AR) +
May take some work/modding to get that, or any other PSU, to fit into his HP PC if that's where the OP's friend intends to run it.
zShowtimez
544
Also be careful of adding a 3rd party PSU to a computer like that. May be a different pinout on the HP motherboard.
Aug 11, 2008
10,451
642
7790 ($100AR) +
I believe a GT650 doesnt require a 6 pin connector, but has lower performance than a HD7750 which also does not require a 6 pin connector. Any nVidia card above a GT650 does require a 6 pin connector. But since the OP specified a 150.00 price point, I think he wants more performance than either of these will give.
Edit: I did not notice in the OP that it was an off the shelf HP system. Unless it is one of the higher end models, it is likely to have only a PSU of around 300 watts with no 6 pin connector, so unless he wants to replace the PSU as well, he will probably be limited to a HD7750.
