Best cpu / socket path for me (AutoCAD & encoding)
JonnyBlaze
3,114
I have somehow managed to keep using this old p4 northwood system for a long time. I want to upgrade. I'm confused about going to i7, cqd, i5 etc...
Is the i7 920 a good choice? I live near a Microcenter so I could put it up for $199. Everything else I would probably get at Newegg.
Any input would be great.
thanks
JB
aigomorla
21,044
3,524
the i7 platform has 8 possible threads with HT ON.
Will give you the best performance out of a single processor which is multi threaded.
However that performance will cost you a pretty penny.
lsv
1,610
Fairly expensive yes. Compared to other boards anyway.
Arkaign
20,736
1,379
I did some research recently on this, and AutoCAD, AutoDesk, and most other similar software doesn't really benefit from multi-core at this point in time. I guess it's tricky to program due to the very sequential nature of most of the work (ie; workpart 1 MUST be done before workpart 2 can begin calculation based on the results of workpart 1, etc).
Encoding, OTOH, benefits MASSIVELY from multi-core and HT.
Best answer, i7 920 is the best route I could think of there.
douglasb
3,157
thanks
JB
Buy it. That's the best available socket for what you're trying to do.
lopri
13,310
687
How you managed AutoCAD and encoding on Northwood is difficult to imagine. Upgrading to i7 will be literally a night and day experience!
Arkaign
20,736
1,379
AutoCAD is just crap on pretty much anything, being notorious along with Autodesk Inventor for STILL not really supporting SMP. Encoding on a Northwood was equal or better than most single-core AMD64 chips. I agree though, an i7 will be a ridiculous upgrade considering Northwood was circa 2002 tech :p I wouldn't expect miracles with AutoCAD though, probably the fastest AutoCAD performance would be on a 4.5ghz+ E8xxx series.
