- Nov 29, 2013
- 3
- 0
- 0
I want to buy AMD FX-4300 because it runs better in multi-threading: http://www.cpu-world.com/Compare/302/AMD_FX-Series_FX-4300_vs_Intel_Core_i3_i3-540.html
I usually run multiple instance of same application in my PC. For example, muliple windows of internet explorer, photoshop, visual studio etc. are open at the same time and run at the same time. Is it multi-threading? Is more core better in this case? A CPU that is better in multi-threading but worse in single threading environment, will work better in this case? Or processor with more number of cores but at lower Ghz than lesser core CPU is better in this case? What things should I keep in mind while buying a CPU for such kind of usage?
