Best CPU Fan for SFF
PAW83
9
What is the Best inexpensive CPU Fan to fit in a SFF computer? I have a Socket 775
RallyMaster
5,581
Good luck trying to get most to fit. From what I remember the Zalman CNPS7000 is about the smallest you can go....
Zepper
18,998
It's hard to know without clearance measurements and pix of the inside of the case.
.bh.
Skott
5,730
Zepper is correct. The case you are going to use will determine hsf size.
Zepper
18,998
I'd say that a radial fin HSF like the Zalman mentioned above would be the most effective that would fit in there. There are quite a few of that type out there like the Tt Orb models. The main problem with that case is height. I think you should have at least a 3" radius from the center of the CPU socket to the side of the case so the even the Zalman CNPS7700AlCu or Blue Orb would probably fit. A number of other brands also have radial fin HSFs like Masscool, Spire, Coolermaster, etc. Any of those should do you.
I normally buy either aluminum or aluminum with copper core - I don't think all copper is worth the extra weight and expense (when the current high copper cost gets to the channel). Of course any other low-pro design would work, they probably won't be as effective as a radial fin design though. Also avoid HSFs with custom fans that can't be replaced with a normal one in some way as all fans will eventually die. The zalman (thus probably the Orbs) can be replaced with a normal fan motor removed from its frame - there are articles on the web about it.
And the fins don't need to be anywhere near as long and fancy as the Zalman/Orb to be effective. Mine isn't much larger than the cpu socket itself.
.bh.
Zepper
18,998
No, you generally can't run passive on today's high-performance CPUs - they throw off too many Watts of heat, though some have by using those monstrous Scythe heat sinks which won't come close to fitting in your case.
.bh.
