I just got a TT Armor full tower case and a Tuniq Tower 120 delivered today. I'll be mounting the Tuniq on an X6800.
I got a Yate Loon LED fan for the Tuniq. It is not adjustable, it spins at 1300 RPM...while the stock fan is adjustable from 1000 to 2000 RPM.
Yes, I wish to OC the proc. How much OC with stability, I assume, will depend on the air flow in the case with a heatsink fan that maxes out at 1300.
Conventional wisdom tells me the fan in the Tuniq should direct air from front to back, pushing air toward the exhaust fan. This is the way the TT was designed anyway for best case temps.
However, what if I were to reverse the direction of both the rear-exhaust (so it blows directly at the Tuniq) and the Yate Loon inside the Tuniq (back-to-front)? This will obviously will bring in more air, although there is considerable open area at the top for warm air to flow out both naturally (as well as with the top fan and top-rear fan). In addition, the Mushkin PSU I got is a dual-fan.
What say ye? Would reversing the rear 120 case fan and Tuniq fan provide more CPU cooling, or am I better off with the current airflow design?
Thanks
Thanks
