Question Best cpu air cooler for 3950x no oc + video work?
note235
I'm looking to upgrade my cpu cooler for my 3950.
I was thinking of the Deepcool AS500 but that doesn't seem to be available. Looking at
Noctua NH-U12S
I'd prefer to spend around $50 but can go more if needed. My primary workload is video rendering so I will be using all the cores. No OC though.
Upgrading my mobo to a Asus TUF X570 Gaming + I have a MSI Geforce Ventus 3X 3090
For that CPU, I would personally go with either the NH-U14S or NH-D15S.
I'd only go with the NH-U12S if didn't have the space for one of the bigger coolers. You are going to use a $750 16 core / 32 thread CPU, so the extra surface area and bigger fan would be a good thing IMO.
They are $5 - $30 more, but a Noctua cooler is something you can use for a very long time, and they even give owners free mounting hardware when a new socket comes along so you can use it in your next build as well.
U14 of D14 for sure.
not to mention the 140mm fan is quieter, sink has more mass, which means can take more heat.
