Slomo4shO
I currently have all fan slots filled (2x 80mm at bottom, 1x 120mm rear, and 200mm top but am currently looking for replacement fans) and a Seidon 240M mounted in the front in push configuration with stock fans (looking for fans for a push/pull config).
The CPU temps are bearable and the drives remain cool. The issue I am running into is the GPUs. I currently have a quadfire setup with 4 MSI TF3 7950 and the 3rd card is having a real difficult time maintaining acceptable temperatures. Under load, cards 1 and 2 remain around 85C and card 4 usually sits at 73C but card 3 goes above 103C. I have tried both intake and exuaust for the top fan and didn't see any noticeable difference in load temps.
Besides an extreme custom water loop, what steps can I take to reduce the temps of this GPU? I do have a spare Seidon 120M with which I may be able to red mod the 3rd card and mount the radiator to rear exhaust but this would leave the memory and VRM exposed. Thanks.
