Well in this Review the 2.4A was taken to almost 3.3ghz on a stock cooler so a Zalman would definately be enough. Of course if you want to take it as high as you can Thermalright SP-94 will offer better performance but at higher noise levels. You probably won't be able to reach past 3.6ghz without watercooling or other means though. Of course the A processor is missing Hyper-Threading and with a multiplier of 18, you'll only reach 800FSB of the normal C processor at 18x200 = 3600ghz which is tough on air cooling. So a 2.8C@3.5 will run at 250FSB or 1000FSB effective and have Hyper-threading so your CPu won't be as fast due to these factors as a similarly clocked Northwood core. But for the price, I really think it's a great deal.
If you didn't buy the processor though you should still consider a 2.8C at $164. It costs $34 more than a 2.4A Prescott, but then you could overclock it to 3.5ghz and Zalman cooler will suffice. They are both great so let us know how you do.
You should let us know if you plan on overclocking... and realize that a lot is going to depend on how well-ventilated your case is. The best your CPU's HSF can hope for is the ambient temperature inside your case.
I was very happy with Zalman's CNPS7000A-AlCu (or something like that) with my overclocked 2.4C, it was quiet and maintained very respectable temperatures.
