Originally posted by: Arkane13131
its relative to the cash you want to put into it. the freezer is 25$...the zalman is 60+ the ninja is 50$ without a fan... the typhoon is 50$
if you poor and dont overclock insanley...freezer is ok... if you rich get that ninja and stick a big ol fan on it.
Ninja is $35 at jab-tech.
Originally posted by: eits
big typhoon = pain in the ass to install, but it's awesome. the fan only spins every once in a while.
Originally posted by: PSUPef2k
does the opteron 170 come with the "good" stock AMD cooler?
Originally posted by: aigomorla
GO WATER!!! 😀 but personally, i would go with a ninja if u have a rear exhaust port, because the way its designed all the hot air can get blown out the rear, but on the TT BT, all the hot air is blown back to your board and theres an annoying PWMIC right next to it, so it tends to heat up the board :X
But thats my two cents.
But ive installed and used the TT BT on my other system and it works great, the ninja does as well, but these things are really massive and heavy.
My choice however would go with the SI-120. Its closer to the board so it causes less torque strain, and the differences between it and the others are about 1-2degree's
only the best for OEM. I believe it uses the heat pipe cooler which shows its about even on par with a XP-90 from thermalrights 😀
