Best cooling fan / system for PS3?
BuMMiE
290
I have the 60gb PS3 and it makes a lot of noise and gets pretty hot. I put it in an open area that allows it to get as much air as it needs for cooling. Does anyone know of a good solution or which cooling fan is recommended the most? Thanks
DaveSimmons
40,730
670
Some people claim it rus cooler & quieter if placed vertically instead of horizantally, you can try that. If memory serves the side vent is right side so it would be left side down.
SOSTrooper
2,552
I placed an Antec laptop cooler underneath the PS3 for a few months now, just to get some airflow going.
hans030390
7,326
The best cooling system/fan is the PS3 itself. Nothing else is needed.
Perhaps you should call Sony about it?
Calculator83
Banned
Nov 26, 2007
890
For the PS3 you just need ambient temp control. I had it next to my computer, "P180", and i noticed the aluminum panels on the ps3 side was very toasty. So i had a small desk fan blowing air at the area, and both were cold to the touch.
