Best color tint for computer glasses?
Miramonti
28,653
100
I need some tinted computer glasses to reduce eye strain and glare. What color tint is best in this case...gray, amber, green, red, blue, purple, yellow?
SKORPI0
18,471
2,411
http://www.gunnars.com/how-they-work/
amber lenses add additional contrast to define shapes and sharpen detail for easier viewing
GUNNAR offers the only patented computer lens technology solution, recommended by doctors, to protect and enhance your vision. Our custom and complete solution addresses and alleviates all common issues associated with digital eye strain, effects of artificial blue light, visual stress and fatigue.
http://www.allaboutvision.com/cvs/computer_glasses.htm
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Brightness? Adjustable.
Contrast? Adjustable.
Color temp? Adjustable.
Computer glasses? Bwahahahaha dork.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
I'm sure you're intelligent and mature, which is why I'm choosing to not judge you based on your posts in this thread so far. Please move on.
You know you're in ATOT right? I hear skinny jeans alleviate eye strain by forcing the blood to your head. I suspect they will fix your unspecified eye strain at least as well as computer glasses.
Miramonti
28,653
100
Dude, really?? Fuck off, out, and away. You're not wanted.
Beer4Me
564
20
OP, is this you?
images
Carson Dyle
8,173
524
It's funny how many people I see lowering the contrast on their monitors, thinking that it's easier on their eyes. I go for the highest contrast I can while still being able to discern color gradients. Brightness is probably less important, but below a certain level it affects the amount of contrast you can achieve, so I usually keep brightness fairly high as well.
Amber lenses help increase contrast. Of course, if you haven't already raised the contrast of your monitors to their maximum usable level, it would seem kind of silly to wear special glasses to do the same thing. I've never worn colored glasses at the computer, but if your monitors are adjusted to their maximum usable contrast level, then I would think the glasses might be counter-productive.
One of the best recommendations that I've read, which actually helps my eyes, is to keep monitors positioned mostly below eye level. It helps to keep your eyes from drying out as much, I think mostly due the position of your eye lids.
Elixer
10,371
762
For what it is worth, I have tried 4 pairs of "computer" glasses, and they didn't really do anything of value, usually, they made things worse (like color issues, headaches, sharpness problems, and annoying to keep them on, only when you are at a computer).
If you do have eye strain problems, then the best cure for that is to get a poster on the other side of the room, and just look at that from time to time. (Seriously!)
Then, get a good quality IPS monitor, and then, I find that most issues have gone away.
Childs
11,313
7
You can buy simple frames with poly lenses and just add an amber tint and anti-glare coating. I found that it just prolongs the symptoms, but they will still occur. Eventually you'll need to just look away from the screen for a bit, so you can save yourself the $30 and just look away every hour or so for a few minutes.
