Best color mouse pads for optical mouses?
NotoriousJTC
1,406
I read somewhere that when owning a optical mouse it's best to use black mouse pads. or something that's not refective. I currently use a dark blue(not quite navy) mouse pad. Should i think about getting a black one? If someone could elighten me on the subject id appreciate it. Thanks.
tigger80
1,198
i have a black mousepad made by belkin. it doesn't really matter, i just prefer the surface to be really smooth on my optical mouseman by logitech
setaanbomb
Banned
Oct 24, 2000
284
Is it actually proven that colors reflect more than eachother when a laser is pointed at them?
If not, then color shouldn't matter.
Ulysses
2,136
I thought they didn't need a mousepad. Nonetheless, I use a gray 3M Precise Mousing Surface. It is very thin and works well.
Noriaki
13,640
I use a piece of grey plastic. It's got blue lines on it (rules actualy..it's like a drafting mouse pad or something).
Just make sure the surface isn't reflective, and you're fine. They don't need to be black.
