- Sep 28, 2002
- 226
- 0
- 0
Hello. Just wondering if I can get advice from some pros on how to best replace thermal compound (I've never cleaned paste before -- only applied paste -- but it seems like a messy job, so I was wondering if there is an easy/clean way to do this).
I have a X2 3800+ with stock fans. Oddly enough, I could have swore there was no thermal paste when I first constructed my system 2 months ago. However, over the last week, I have had to reseat the heatsink 4 times (primarily because I had to move the processor from one Mobo to another, and then back again) and I had noticed the sticky paste which practically glued my heatsink to the CPU -- I had to twist and turn it a little to get the heatsink off. When I first made my system, it would idle at around 42C. However, after moving it to one mobo to another, and then back again, I now notice that it idles at around 44C - 45C.
Does reseating the heatsink multiples times cause an adverse effect on CPU temp? I was just wondering because it seems to me that the first time you apply a heatsink is the time when the paste is applied most evenly. If you reseat the heatsink to the CPU too many times, doesn't it start to make the thermal paste coating less even?
Anyway, I bought myself some AS5 compound, but I first needed to get rid of the stock thermal paste first. I know with the heatsink I can simply take off the fan and then run the heatsink under some water since it is only metal, but for the CPU I was wondering what is the best way of cleaning paste off of it, since I obviously don't want to rub it with water or such.
Ideas?
Ideas?
