- Sep 5, 2004
- 6,666
- 3
- 81
I need to add a PCI USB card to an older PC (P4 2.4 Ghz). Any thoughts on the best USB chipset available, in terms of CPU utilization and throughput?
Originally posted by: techmanc
You can goto the link and check the different External USB Ports on the advanced search options and read the reviews there.
http://www.newegg.com/Product/...StoreType=&srchInDesc=
The high cost of Belkin cards are mostly from markup/marketing/better warranty, but Belkin cards do have a higher quality standard than all of the generics I've seen. It's hard to find high quality generics, because they're all made to be as cheap as possible...besides being able to promote a particular brand chipset, there's no other incentive to use better components.Originally posted by: Zepper
Belkin cards are the same as generic with a much higher markup to help the big box stores improve their margins. It has to be an amazing sale on them to make them worth the cost.
.bh.
