Best Case with Temp Display?
solrac
Hi all
I am building a new computer and looking for a new case. This computer is for my wife and she wants something thats rock solid.
The system I am thinking of building is to use
2- 7200 SATA drives in Raid 1 (yes in mirroring not striping)
1- 7200 for temp and scratch
1- DVD/CD player
1- DVD +- RW Writer
1- Video card probably a ATI9600
1- SB Audigy
1- SCSI Card (for her old scanner)
And all the rest of the stuff.
The real big goal is to make the computer resilant as she lost alot of data on her last hard drive failure. She is looking for a black case what do guys recommend? Let me add that I am not going to be moving this thing around much so size or weight doesn't matter.
if money is no problem then by all means go with a wave master as mentioned above and good quality psu. the sonata from antec is also a fine black looking case and if you wanna go a bit cheaper there is the SLK3700 BQE.
thanks for the replies guys. I like the wave master but it does not have a external display and its not black any other suggestions?
Ok guys it looks like maybe I don't need to consider having an display built into the case and use one those units that shows everything. Is there anyone that works better than any other one?
Guys--he wants an external temperature display...
Only one that I know of off the top of my hand is the antec p-160, it's a good case too.
Sorry I'm botchin the name
Ahnix Dbox. the case looks NICE, you can get a black one, and it has the temp lcd.
might I suggest a Wavemaster with a CoolerMaster Aero2, the Aero2 is temp thing that sits in a 5 1/4 bay.
I have one in my case, it really looks sweet!
