I got a bit carried away with the my new Skylake build and need to find the best case that has enough CPU cooler clearance to accommodate a Noctua NH-D15 cooler and G.Skill Trident Z ram.
Trident Z are 44mm high and the standard clearance under the 2nd fan of the D15 is 32mm so I need to raise that fan by at least 12mm which will increase the total height of the D15 from 165mm to at least 177mm.
The cases (with clearances in mm and Perth, Western Australia prices) that seem to give enough clearance include:
NZXT H440 Black 180mm AU$138
Corsair Obsidian Series 550D 180mm AU$185
Fractal Design Define R5 180mm AU$179
Corsair Carbide 500R 180mm AU$159
NZXT Phantom 530 183mm AU189 ($149 Red?)
NZXT H630 190mm AU$199
Corsair Carbide 600Q 200mm AU$189
NZXT Phantom 630 200mm AU$229
Corsair Graphite 780T 200mm AU$259
I was also interested in the Phanteks and Be Quiet! cases but they are not available in Perth and freight makes them too expensive. I also contemplated the Thermaltake Core x9 which has 250mm clearance and amazing looks but came to the conclusion that this might be overkill!
I will be overclocking, so cooling is important but at the same time I would also like a quiet case. Within reason, overall size and price are not important factors.
The PC will have an Asus Maximus VIII Hero MOBO, i7 6700k CPU, Samsung 950 Pro 512GB M.2 NVMe; 32gb ram, a GeForce GTX 1080 (when they are back in stock and perhaps a bit lower in price) and I may re-use 2 to 3 HDDs, 2 extra SSDs, a DVD burner and a hot swap HDD dock from my existing PC.
Any advice or recommendations would be really appreciated!!
Thanks!
Thanks!
