Like an idiot I spent $130 for a Lian Li case. Yes, the case is beautiful and incredibly well designed but here are a few issues I didnt think about -
1. Its TOO nice. With the nice aluminum finish I know I'll be worried at LAN parties and moving, etc...
2. The airflow isnt very good. My case temps are quite high and I've noticed the air intake isnt too great. I had assumed 2 80mm fans in - 2 80mm fans out would be fine...
3. The case fans are not nearly as quiet as I had expected.
If I replace the stock case fans will it make a difference in both sound and/or case temps? So, if I could go back and buy a different case - what would you guys recommend for good airflow?
