Best case for cooling?
seiyafan
Suppose I do air cooling with overclocking, what is the best case that can give me the lowest cpu temp, and possibly chipset temp. btw, I am not talking about those weird cases like the one with a built-in AC. Right now I have P180 and I am just wondering if there is a case out there that can help lower cpu temp by more than 2-3 degrees. Otherwise it's not worth an investment.
I'd stick w/ the P180. IMO very few, if any, cases out there have the air-cooling potential that can be achieved with it.
Stick with your P180. Add a 120mm intake fan to the front, and flip the top 120mm fan so that it's also running as intake. This should bring more cool air in and lower temperatures significantly. Also, take the spoiler off the top if you do switch the top fan around.
Both intake fans.....
I have 8 fans of which only 1 is an exauhst fan,,,thats the 120 mm in upper rear of the case....
You really should have an exhaust fan instead ot all your fans being intake.....
Unless I am missing something.....🙂
