Best case for £100?
spat55
539
I am running a Cooler Master Elite 430. The case has no cable management whatsoever, so I have a massive bundle of cables right in front of the PSU.
The case I would like should have 2x 120mm Fans on the exhaust, one massive case fan on the front (Maybe two) and one on the side. I also want to be able to hide all the cables down the back of it quite easily.
TLDR:
2x120mm Fans exhaust
1x140mm Front fan
1x120mm Side
2x120mm Top
Long enough for the highest end HD 9xxx series or whatever later on.
EDIT: I like the look of this! But the price :-(
http://www.nzxt.com/product/detail/96-phantom-820-full-tower-caes.html
Corsair Cabide 500r looks good and in my budget.
spat55
539
How much hard drive room do you want or need?
Two I would consider if you care about how nice your case looks.
http://www.newegg.com/Product/Produc...82E16811139012
http://www.newegg.com/Product/Produc...82E16811163188
Or I would try to grab a silverstone tj07 or one of the big Lian-li cases used, such as the v2100 plus or A75.
I only have one 1TB HDD, it is just a gaming pc really. I am going to be doing a overhaul on it soon, sometime in October/November, depending on when the new cards arrive. This overhaul is a new case, a 128GB SSD drive (for OS) and a new GPU (if they are really good, otherwise another HD 7850 in crossfire will do).
