Best card for dual monitors & 2D? HELP!
Implicit
I'm building a new system and am looking for a new video card. In the last few years I've mostly been using a Matrox G400. Since most of the cards these days are all around gaming and 3D is hard to find out what will be a good card for my application. My requirements are as follows:
- Rock solid stable drivers
- Highest quality 2D performance
- Best Dual Monitor support
I mostly use this workstation for Audio and Graphics work and I play NO GAMES at all.
Any help would be appreciated.
System Specs
Abit NF7-S
Athlon XP 2400+
Crucial Dual DDR3200
Implicit
I initially thought about the 550 but I thought I might do a look into what nVidia had going on before deciding to pull the trigger. The G550 is a few years old now and just trying to make sure if its still the best thing for 2D quality and dual-display support before dropping some bucks. A lot of the GF440 and Ti4200 boards are pretty cheap now but I've never used nView or any of the nVidia cards to know about the quality, etc. Basically I don't know if a high-end 3D board with tons of ram makes it decent for a 2D board, etc. Opinions?
Implicit
Ended up just ordering the G450. Didn't need the DVI the 550 added and otherwise the cards are almost identical. Would still like to see who else has good multi-monitor 2D offerings.
ProviaFan
14,993
Most mid to high end cards from ATI and Nvidia have dual output capability (mostly HD15 and DVI - very few dual DVI cards exist, and they are pretty expensive). ATI has a lead over Nvidia in 2D IQ, but it's not as noticable now as it was back a few years ago. Neither compare to Matrox in raw 2D IQ on an analog connection (also known as HD15, or VGA).
