Best cable to get for my Z560s?
brtspears2
8,659
I was looking at some 16 gauge Monster Cable, THX certifed cable... and just a spool of generic 16 gague shielded all copper cables.
Which would be best? Any suggestions? Online stores best.
Also need to know places online where I can get cable on the cheap.
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
I used 16 gauge wire from Radio Shack on my Klipschmonsters and it sounds great. Im not sure if spending the extra $$$ on 'nicer' wire will do any better than the cheaper stuff.
TheWart
5,219
i wouldn't spend the time or effort. if this was a multi-thousand dollar HT then maybe. but for $150 these sound pretty darn good as they are. my advice is not to fall for the "monster wire" trick whatever else you do. just my $.02 wish ya luck anyway
Goldfish
2,157
Not much difference between something you pick up at Wal-Mart and the Monster Cable at Best Buy.
heartsurgeon
4,260
just use regular ol' power cord wire from home depot -
if you feel the urge to give your money away - give it to a charity rather than for "monster" cable.
