Whats the best connection for best resolution? What do ppl use for 144hz?
I know hdmi will only transmit 60hz. I also read that dvi cables are the same way(although i always thought dvi was supposed to be more superior??)
Is it jsut the dvi connection or the cable? Bc if i go with a display port or mini display port, i would just be using an adapter to connect to either a vga cable or a dvi cable.
