- Jun 30, 2004
- 16,386
- 1,913
- 126
I have to decide among the possibilities for an AiO cooler, preferring that it be "custom-izable" for expansion or replacement. None of the prices for AiO coolers I've seen are prohibitive; some could seem a better bargain than others. I can't sacrifice reliability for performance, but I want performance near the top of the heap in some very inclusive comparison review, some often linked in to Frosty Tech's web-site.
The H240 X2 and even the H220 X2 have poor customer reviews, and the tally of all reviews shows a lack of popularity. But the units have a copper-brass radiator, there's a fill-port, and one could think a user would go through some sample of tribulations that builders of custom watercooled rigs experience as routine in the process of getting things to work. I don't know. Someone could comment about my guess.
The Corsair Hydro H115i has more reviews, or about 74 of them at the Egg and considerably more than the others. It has 89% favorable reviews of 4 and 5*'s.
It has an aluminum radiator.
Then there's the EKWB Predator 240. Like the H240 X and X2, it was also built for expandability, but I heard there was either a recall or a defect EK would only have chosen to address. But what's the latest on these?
The chosen cooler must fit in the drive-cage of a Stacker 830, or optionally within a Corsair Vengeance C70. While the H115i is a compatible option in Corsair's list, it does not preclude using one or more of the others. As for the Stacker, it allows for a 140mm square fan inside the cage with 1/8" or so clearance on each side. At maximum, the length of the assembly shouldn't exceed 300mm if I need to use two 5.25" drive-bays for external access -- hot-swap, switches, USB3 ports, optical drives or LED panels.
Customer reviews always reflect a larger percentage of negatives if consumers have more reason to complain. A QC sample may show a smaller percentage. However, complaints of a similar nature would either forwarn of impossible problems, or indicate procedures for correcting those problems before fully deploying the cooler.
