Best available pci-e low power gpu no pci-e power needed?
evanesce
49
Basically all in the title, looking to max out an old system. Don't want to spend a fortune, either.
Edit: also forgot to mention, just single slot width, the system can't handle double slot.
ELopes580
3,888
11
I was in the same boat with a Core 2 Quad Shuttle box. The only thing that matched the same criteria was a Radeon HD 7750. It works well enough since I'm only playing older games right now.
evanesce
49
You're all saying the same thing, HD7750 it is! Love these forums, what a lightning fast x3 response ;)
EDIT:
Actually, got another question... What is the next best card? I've seen these 7750's are the top of the line for what I'm trying to do, and the price is pretty stable at around >=$80, is there something in the HD6xxx range? I've heard also a 6xxx card would have better hackintosh compatibility.
coffeejunkee
1,153
Yes, or rather 7750 is really fast for a card without extra pci-e connector. But it depends on your resolution and the games you want to play. For 1080p and games less than 3 years old I'd definitely go for the 7750. For 720p and older games 6670 is fine.
evanesce
49
Is there anything between the 7750 and the 6670 that doesn't require PCI-E power? Those are basically my two choices? I think if this is so, I should just probably fork out the extra $15.
joshhedge
601
While it may be an extra $15, the card will remain relavent for longer, saving you money through purchasing a new card sooner. I think also due to the 28nm process vs 40nm the 7750 might also use less energy, although don't quote me on that.
Insert_Nickname
4,109
680
The 6670 is actually less efficient then the 7750 (66W vs 55W TDP). Plus that the 7750 has the newer GCN architecture. There is not much in between, that makes sense to purchase. The GT640 is also more or less equal to the 6670, so that's a possibility too. Anything higher then a 7750 seems to require a double slot cooler unfortunately...
svenge
204
I'm pretty sure that ASUS makes a GTX 650 that doesn't require a PCIe connector.
Insert_Nickname
4,109
680
You're right. Well spotted. But that looks like a two slot cooler (though it does look more like a one and a half slot cooler on closer inspection... :)), and the 650 and 7750 is roughly equal in performance. But it is an alternative, if the OP can use it with the slightly out-sized cooler.
ASK THE COMMUNITY
