Originally posted by: asdftt123
Yeah I agree that $175 is a lot for a soundcard, but I want to get the most out of my audio and video, and the Claro seems to be better than anything Creative has ever put out. I've also heard Creative has utterly horrible Vista drivers and customer service. I figure it would be a decent investment since I doubt soundcards will become obsolete as quickly as other PC components. Anyways, I unfortunately, know nothing about "real" speaker and surround sound systems. I don't want to go over the top in terms of sound, and I'm pretty sure I'll be happy with a nice computer speaker setup. Also, for anyone out there with the Z-5500, can you really tell the difference between a set of $50 speakers that will justify the $250 price tag?
On a side note, does anyone know of alternate soundcards I should consider? I've heard good things about Bluegears b-Enspire and I read somewhere that Auzen is releasing the X-Fi Prelude in a week. It's even more expensive than the Claro Plus+ so what are the strong points other than full EAX support? Will it have the same audio quality for music and video as the Claro?
There is no "over the top"
I've tried a variety of pricepoints over the years and there are great bang-for-the-buck components for whatever pricerange you're looking for whether it be $50 or $5000+
Initially looking at a $175 soundcard choice, it seemed to me that you'd want to get the most out of it. Your sound system is only as good as your weakest link.
Bad source material, bad soundcard, bad sound system... you want to make sure you're getting the best balance. That's a very expensive soundcard and your goals seem to be for high quality sound reproduction.
I've tried
Logitech speakers and
Logitech subs as I used to use them as my first decent system.
They're a pretty decent option for what they are, but if music quality is what you're after, they may not be the best choice for you. If you're looking for "speaker wars" type battles in the dorms, they're fine for that. I was happy with them for several years before I found out what a "real system" could do and my eyes/ears were opened. I honestly don't regret getting the Logitech set since I got several years out of it and sold it for only about $50 less than I paid for it, but I'm even more glad that I eventually moved on to something better.
If I had to do it over again knowing what I know now, I'd probably just use integrated digital out to a low-end 5.1 receiver, a basic dayton sub (or something similar for budget), and get a decent pair of bookshelf speakers.
With that system, I'd have an upgrade path to completing a 5.1/7.1 system once I had more space and a bigger budget without needing to throw anything away. Eventually once I'd have a surround system, I'd be able to get a soundcard to take advantage of that with DD/DTS encoding and hopefully by that time things would be a bit cheaper, more stable, and fuller featured.
Back when I was in HS, I didn't know you could easily hook "real" speakers up to a computer and just assumed that the "high end" sets from logitech/klipsch were the best I could do. They're an easy thing to get set up and I agree that you'll probably be happy with whatever you end up getting, but at the very least get something like a z-5500 / Klipsch promedia set if you go with computer speakers. If you like the idea of having a higher quality 2.0/2.1 system initially with the option to expand it to surround sound eventually, please consider your options with "real" speakers.
Good luck :thumbsup:
