Question Best Anker USBC Cable for my MB
LOUISSSSS
8,771
58
I have this MB Above: Aorus B450 Pro Wifi
I know it has 1 x USB Type-C™ port, with USB 3.1 Gen 2 support, which I assume is the latest and greatest.
Can someone recommend me the best 6ft Anker (cuz they're the best) cable to fast charge my Samsung Note, and S10, And any other future USB C devices I have?
Also, does my mb have a USB C header on the MB to work with a front panel on the newer cases? If so, i'm going to consider getting a new case.
LOUISSSSS
8,771
58
I went with these ones and have had zero issues with them. Using them with my S10 and fast charge is working.
Not sure about the header question. I'd suggest viewing the pinout in the manual and case in question if they look to be compatible.
Thanks, but I was searching for a USB C to USB C cable since that's where you can get the fastest charging, unless i'm mistaken?
Kenmitch
8,505
2,250
I'm not sure about charging speed as I just plug my phone in when needed which is mostly at night.
LOUISSSSS
8,771
58
Just plugged in a USB c to USB c cable to my rear USB c port on my mb with the pc turned off. It is charging my phone, but super slow, from 70mA to 700mA. I know this thing can go 2000+mA,how do I set this to work when my pc is off?
cj274
Banned
Mar 1, 2020
18
Look at you, demanding answers. Why not just freaking google it. This is what you get. In this forum, begging for answers
cj274
Banned
Mar 1, 2020
18
bro, r u ok?
dont act all victim-y right now. you well know what you did. everyone knows youre an DELETED
Don't harass people and don't post profanity in the tech boards.
AT Moderator ElFenix
