I have a SLOT A motherboard, so I need to purchase a SLOT A thunderbird.
I know I can overclock it with a GFD device, but I will just try to change the bus speed first..
What is the best *CORE* to purchase that overclocks the best?
Im not a rich man, so I was looking at between 700 - 900 mhz (900 mhz can be had for $190)
Also which fan set up will keep the cpu coolest? (Im thinking a GlobalWin VOS)
Thanks
lex
Ps. also if you can reccomend good RELIABLE vendors (that are inexpensive)
Thanks
lex
