Best AM2 Motherboard for less than 40$
semlethe3rd
74
My friend needs a cheap motherboard to replace the one that just died on him. He already has cpu / memory / gpu but just needs a motherboard that will support all of it. Links and recommendations would be appreciated, thank you =)
semlethe3rd
74
There are some on newegg, im just seeing if anyone knows of any good deals. I honestly don't care if its a higher quality motherboard thats open box, I have plenty of connectors / other stuff laying around to make up for a box with only a motherboard.
Zap
22,377
7
Originally posted by: tcsenter
Personally, I'd go with the 740G + SB700
That's what I'd do too, if staying under $40. Note that the board only supports up to 95W processors.
If semlethe3rd's friend wants a bit of future upgradability, perhaps consider the Foxconn 780G chipset board which will support up to 125W processors. It is currently $67 shipped.
jedihobbit
232
semlethe3rd, what was the outcome of this??? I've picked up a A74MX-K to play with........:laugh:
hans007
20,212
18
the a74mx-k is probably the best board for $40 at newegg.
i have the 780g version of it and its a great board, has lots of overclocking options even and a dvi port.
it also has am3 support... the 690v foxcon=n doesnt.
