Best airflow set up for Corsair 200R?
UnholyCarcass
45
I have a Corsair 200R and it gets dusty even with my current fan set up. Granted that the fans are not the most powerful what is the best fan set up that would eliminate the dust buildup in my case (assuming i can fill up all the fan slots)?
lehtv
11,897
74
The best way to eliminate dust buildup is to not have a dusty room. ;) It also helps to have the case sit on the desk instead of the floor.
200R has lots of openings where air can get in without being filtered. In particular the top is completely open.
You could make it relatively dust proof by first adding a filter for the front fan, then installing another filter and intake fan on the floor. Now you have two fans blowing in, and one fan blowing out, resulting in a slight positive pressure which, in theory, helps eliminate air getting in through unfiltered openings. Finally, cover the top openings with something, e.g. magnetic filters, or you can conjure up some DIY solution.
