Best Air Flowing Case
Hello
My centrion 5 doesn't seem to have good air flow. Only has 2 fans front and back and I don't thik the stock fans work that great. Should I just upgrade the fans and mod the case or is there a good air flowing case that's worth to buy?
I'm looking around 100$ not more than 120$
I replaced all my fans with Nexus models and I added an extra 120MM fan into the bottom of the 5 inch bays. Leaving one of the break-away grates in allows for perfect mounting of the top two screw holes on a fan. That, tied with respectable cable management means that I have absolutely no cooling issues that are case related. The stock fans are a bit anemic...
They can't be very high, but the centurion 5 is pretty good in terms of airflow as far as airflow goes. If you do feel the need for an upgrade, the lian li pc7b +2 is a good choice @ $95 shipped, it can two 12cm fans and is all aluminum. (plus it looks way cooler than anything coolermaster puts out... except maybe the stacker, or mystique) I think lian li uses adda fans that are rebadged to say lian li brand.
you say it doesn't have good airflow - Anything running abnormally warm? Yeah the fans don't have much guts but the computer I built with that case has no cooling issues with the stock fans. Granted it is only a 3000+ with a X1600XT with stock coolers
Welll the CPU runs 40 C Idle. I have e6600 with Scythe MineCooler.
I just upgraded the rear fan with Thermaltake and lowered 1C lol
I wanted to overclock sooner or later but before doing so, I wanted to make sure that I have safe temps to attempt to OC. Should I worry about getting a new CPU fan instead??Any recommendation?
theres a problem with alot of the lian li cases the psu overhangs ther motherboard preventing you from fitting a tall hsf otherwise great cases. get some fans with higher cfm max 19db like the nexus
-who said anything about lian li case's?
-i suggest getting a faster 80mm fan in the front to balance with the 120mm fan in the rear, my friend's WD hdd is overheating like crazy in that case (idle 56c)
Originally posted by: Howard
What's wrong with the air flow in your case?
My thought exactly!
Good air goes in -- bad air goes out -- everyone is happy -- I'll keep reading...
Originally posted by: tastykellogg
Welll the CPU runs 40 C Idle. I have e6600 with Scythe MineCooler...
Okay, I got it!
1) Are you in the Northern hemisphere, e.g. is it summer where you are?
2) I have a Scythe Mine 3 [pronounced me-nay] and it sucks! I can't wait to get rid of this thing on eBay!!!
3) I'm starting to *think* Intel has pulled another (if you'll pardon the pun) fast one on the public, in the name of corporate profit! Either there are a lot of dumb ppl out there, that don't know how to install a HSF properly, or the Core 2 Duo is a ruse -- a clever marketing ploy. And, that's what I'm starting to think...
My question is: Is there anybody, out there, having good luck with these things -- the Intel Core 2 CPUs?
