I need to know what is the best Athlon 64 754-pin motherboard available today. Will be used with an A64 3000+, 1 GB PC3200 RAM, and a Sapphire R9800P. PC will be used primarily for heavy gaming. Ok, lemme hear it!
Depends what you want to do (besdie gaming) and how much you wanna spend.
If overclocking, then look at the Chaintech nForce3 250 that juts came out. You can get one with basic stuff for $80 or a top of the line with envy sound for $175? at newegg.com
