Hi Everyone,
I'm buying a Thermalright Ultima 90 for my Q6600 B3 chip, and I'm wondering what would be the best 92mm fan to accompany it?
As usual, I'm looking for high CFM and low noise. I would get a 120mm fan, but I fear that it won't fit inside my Coolermaster Wavemaster case.
I've heard good things about the 92mm Panaflos. Can anyone suggest something better?
Does anyone have experience with the Scythe "KAZE-JYU" 100mm Silent 100mm Fan which has 92mm mounting holes?
I'm also wondering, since this fan is for the CPU, should I go for a PWM fan that I can plug into the 4-pin motherboard header?
Thanks for your help!
